Rovers North BBS Forums
Go Back   Rovers North BBS Forums > Land Rover Technical Forums > Range Rover P38A
Range Rover P38A Discussion forum for technical items on Range Rover P38A vehicles
Reply
Thread Tools Display Modes
  #1
Old 10-27-2009, 07:59 PM
moosedaddy's Avatar
moosedaddy moosedaddy is offline
Default Engine Timing
Truck is idling a little high...clean the idle air control valve (that helped some....) They have told me the timing is out a little which could cause it to idle higher. Can someone tell me how to adjust the timing?
Trying to get the car smogged and they will not pass it because the idle is not with specs.
Thanks for the help
Old 10-28-2009, 07:57 AM
kevin-ct kevin-ct is online now
There is no way to time a P38 Range Rover. There is no distributor!
__________________
Kevin
92RRC
95 RRC (up for sale)
72 Series 3
Morgan +8 (sold) 8/09
90 jetta 300k miles
2002 E320
Old 10-28-2009, 11:50 AM
moosedaddy's Avatar
Default Timing
Ok..thank you.
Can you tell me what is done in the place of the distributor?
Old 10-28-2009, 05:56 PM
Coil packs and an ECU that controles Ign
__________________
Kevin
92RRC
72 Series 3
90 jetta 300k miles
2002 E320
Old 10-28-2009, 06:49 PM
moosedaddy's Avatar
Default Thanks Kevin
Thanks for the information
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Copyright © Rovers North, Inc. All Rights Reserved.
